Ehammond
#1 Posted : 15 years ago
Ehammond
My ice maker inlet tube did not freeze up for 4 years, now it has frozen up 4 times in the last 5 days. Take a hairdryer to it and a round chunk of ice comes out and it will make ice for a while till it freezes again.
Any Ideas?
Eddie
Rick90
#2 Posted : 15 years ago
Rick90
I have had the same thing happen to mine too. Hope you get an answer soon.:o
John @ Fischers
#3 Posted : 15 years ago
John @ Fischers
If the tube is freezing up, it's due to the water solenoid leaking "through" when not energized.
You will need to replace the ice maker water solenoid valve to fix your problem. Good luck
Ehammond
#4 Posted : 15 years ago
Ehammond
I had just about figured that out. It has stopped freezing up so I wonder if there was a small piece of trash or something not letting the solenoid seat properly.
#5 Posted : 15 years ago
If the water solenoid was leaking it would overflow the icemaker mold.
Most common problem is freezer is too cold due to condenser coils clogged, or other problems. Measure the back freezer wall temperature and post.
Rick90
#6 Posted : 15 years ago
Rick90
Thanks, new one on order. I'm sure now that's the fix.
