gmusil
#1 Posted : Wednesday, March 19, 2008 2:38:37 PM(UTC)
gmusil
I have replaced the 40W appliance bulb, but the light still does not come on when you use the touch pad. The new bulb has been confirmed as OK.
Is there a method of checking either the touch pad or PC board assy. with an ohm meter to determine where the problem is? I've checked voltage at the light socket and get 0 Volts when the touch pad is activated yet the indicater light comes on.
#2 Posted : Wednesday, March 19, 2008 4:48:00 PM(UTC)
Pull the range range, remove the rear cover and check wires to the socket.
If there is nothing wrong then replace the control board.
- The part number for the control board is AP3456298
Here are the break down diagrams for the Amana range Model ACF3335AC
gmusil
#3 Posted : Thursday, March 20, 2008 6:33:20 AM(UTC)
gmusil
Thanks Gene. I have one other question:
What about the plunger switch that controls the light when you open or close the oven door??Could it be bad??
#4 Posted : Thursday, March 20, 2008 7:22:54 PM(UTC)
According to the wiring diagram this switch mostly works as a logic switch. You can check this switch for continuity at the control board (the violet & the orange wires at the J1 connector) with the door open and closed.
Post the results.
