roberts3a
#1 Posted : Monday, March 17, 2008 5:21:33 PM(UTC)
roberts3a
The display on the front is completely out. Range works fine but can not use clock or see that you have set correct temperature.
Anyone know how to determine what the problem is and how to change/fix part?
#2 Posted : Tuesday, March 18, 2008 2:54:22 PM(UTC)
Most likely the problem is a bad electronic oven control (aka EOC) which has to be replaced.
- The part number for the EOC is AP367441
Here are the break down diagrams for the Jenn Air range Model SVE47600B
roberts3a
#3 Posted : Tuesday, March 18, 2008 5:50:48 PM(UTC)
roberts3a
Thanks Gene
