richierich2580
#1 Posted : Monday, March 17, 2008 5:33:04 PM(UTC)
richierich2580
the control locked led light is on and it wont do anything on the display. i've unplugged it for a couple of hours but didnt have any luck. what part do i need to replace. is there more than one board? help!!!
#2 Posted : Tuesday, March 18, 2008 3:47:19 PM(UTC)
Push and hold the "End of Cycle Signal" button for 3 seconds. The controls should unlock.
richierich2580
#3 Posted : Tuesday, March 18, 2008 5:18:39 PM(UTC)
richierich2580
that worked thanks alot! is there a reason that happens or just some weird fluke. i wondered if it was something I did
#4 Posted : Tuesday, March 18, 2008 5:30:34 PM(UTC)
The ability to lock and/or unlock controls is a safety option to prevent non authorized use of the washer.
More likely someone wanted to turn the end of cycle signal "off" and held it depressed for 3 seconds.
