tabanelli
#1 Posted : Tuesday, March 18, 2008 9:14:27 AM(UTC)
tabanelli
The gas oven cycles over and over again before the set temperature is reached. The ignitor stays lit the even while when the gas flow is stopped. The ignitor turns off when the set temperature is reached. I very recently replaced the gas valve. The broiler works normally.
Please Advise. Thanks, Steve
roycreamer
#2 Posted : Tuesday, March 18, 2008 3:09:52 PM(UTC)
roycreamer
Groups: Expert
your ignitor is weak... replace it.
