Appears to be grease or geare oil comng from under aggitator.Is unit worth fixing? Can do the work myself just need a point in the starting direction. Any help
Most likely the problem is a bad transmission which has to be replaced. It's going to cost you about $200 (maybe more) and it is a few hours very serious job. You have to decide if this washer is worth it. - The part number for the transmission is AP2400418 Gene.
Tks for the advice,came to same conclussion earlier.Went and purchased a good second hand machine for $90.
