In looking for gas coils I find the two coils are replaced by one number. Does this number give you two coils? If so, are they like original, one with two wires, one with three wires?
This one part number is for a kit included both coils. It fits all dryers with two coil gas vale made by all manufacturers. - The part number for the coil kit is AP3094251 Here are the break down diagrams for the Maytag dryer Model LDG9304AAEGene.
Thanks for doing this website, I have a Maytag Dryer Mod: MDG3500BWW and in browsing thru your forums my Dryer is displaying the same Problem. The igniter heats up-gas valve opens- flame on for a period of time then off, a few moments later the igniter heats up- and then nothing, no flame, and this will continue to repeat until I shut off the dryer. A period of time will go by and I can repeat the steps. Should I replace with a new coil kit as well? Please advise! I have already looked up the parts, but would hate to be just spinning my wheels without some advice
Hi Pokey, You were right - replacing the coils should solve the problem. - The part number for the coil kit is AP3094251 Here are the break down diagrams for the Maytag dryer Model MDG3500BWWGene.
