emmaus
#1 Posted : Wednesday, January 20, 2010 4:55:25 PM(UTC)
emmaus
My fridge is not very cold on the high settings compresser fan is working and so is the frezzer fan after having doors open and close a couple of times you do not hear it kick up to recool it again.
#2 Posted : Thursday, January 21, 2010 2:53:52 AM(UTC)
Remove the back freezer panel and describe the frost pattern.
emmaus
#3 Posted : Thursday, January 21, 2010 2:22:33 PM(UTC)
emmaus
took it out and the coil was frozen completly up defrosted it with hair dryer.why would it do that and where do i go from here
#4 Posted : Thursday, January 21, 2010 11:54:19 PM(UTC)
Go to the sticky above "GE refrigerator (GSS and PSS models)" and do the manual defrost test, may just be a bad defrost heater, very common with these models. If the heater is bad it will show black inside with a blown out area.
