The timer switch came apart when one of my children hit it to hard. I have all of the pieces of the timer but am not sure where they all go. I need a diagram of what the inside of the timer looks like to put it back together. It is a AP4043083 (33002803) equalivant. The timer itself has the numbers 3133A maytag 6 3720660 m285 Kingston 71016-a01229. Thanks for any help you can give me.
Here are your parts Replacement parts for MAYTAG MDE7400AYW Dryer - Ele | AppliancePartsPros.comI do not know of any site that shows how a timer is assembled. They are usually just a replacement item. I would just replace it as something has probably broken to allow it to come apart. Also depending how it came apart there is a chance that if you put it together incorrectly you could end up with a major electrical short re: arcs, sparks and maybe even fire. |
THIS FORUM IS DEAD!!!!!!! |
