Albert P
#1 Posted : Wednesday, January 20, 2010 6:41:45 AM(UTC)
Albert P
Timer is noisey, I know it needs a drop of oil in the timer motor,
but I can't figure out how to remove the knob to gain access.
There must be a clip, or trick to removal without breaking it.
sidfink43
#2 Posted : Wednesday, January 20, 2010 10:18:55 AM(UTC)
sidfink43
On the back of the timer there should be a hole. Inside the hole is plastic tab. Reach into the hole with a small flat head screw driver and pull the plastic tab out. The knob will now come off.
Here is a service manual. Be very careful with oil around the timer; if it gets on the contacts you will not be happy.
http://www.servicematters.com/m...ibrary/docs/16023083.pdf
#3 Posted : Wednesday, January 20, 2010 10:22:20 AM(UTC)
Here is a manual, see page 3-6
http://www.servicematters.com/maytag_library/docs/16023083.pdf
Replacement parts for MAYTAG PAVT344AWW Washer - Top Loading | AppliancePartsPros.com
Timer is Item 11 in Section 3. Click on it's picture for more views.
I do not think this unit can be oiled.
Albert P
#4 Posted : Thursday, January 21, 2010 5:16:37 AM(UTC)
Albert P
Thank you for your help, I understand that most of these are sealed, but I will take care and be sparing with the oil. I figure if I can't oil it I will need to replace it soon anyway, so it is worth a try!! I really appreciate your warning also. Al
Albert P
#5 Posted : Thursday, January 21, 2010 5:18:54 AM(UTC)
Albert P
Thank your for your reply, and especially the manual, I knew it must be a simple trick, but couldn't see what you explained just off hand. I apprecite your help! Al P
