What does an F10 Error code mean?:eek:
The "F10" oven error code means "Runaway temperature". Locate the temperature probe (#37 on the diagram) wire plug at the EOC (aka an Electronic Oven Control) and measure its resistance. It suppose to be about 1100 Ohms at the room temperature. If the reading is wrong, replace the oven temperature probe. If the reading is correct, replace the EOC. - The oven temperature probe Part number: AP3363354
