Hi:
Our washer sticks on the final spin cycle, i.e. the dial doesn't seem to make the final click to shut off. After spinning for awhile, it starts to agitate gently, but still won't shut off. Everything else appears to be functioning correctly. Any ideas?
Thanks!
does it behave this way on all cycles? or just one cycle .it sounds like timer problem
Seems to be all cycles -- I've tried it on several.
Is a timer fix a do-it-yourself possibility, or is it a bring-in-an-expert variety repair?
