superkev
#1 Posted : Tuesday, January 19, 2010 5:13:53 PM(UTC)
superkev
Our dishes have to be ran through 2 or 3 dry cycles and are still not HOT, HOT or completly dry. Do heating elements wear out with time and should I replace this one? The dishwaher works okay, but doesn't always clean dishes that have not first been pre-rinsed.
HOW DO YOU CHANGE THIS ELEMENT IN THIS GE DISHWASHER? GSD2230F00WW.
Thank you very much
#2 Posted : Wednesday, January 20, 2010 1:57:36 AM(UTC)
Replacement parts for General Electric GSD2230F00WW Dishwasher | AppliancePartsPros.com
[COLOR="Blue"]
Do heating elements wear out with time and should I replace this one?[/COLOR]
Yes heating elements can burn out but it could also be that it is not getting power.
Remove power from the unit (unplug or flip the breaker).
Remove the kick plate and a wire from one side of the heating element.
Measure the element with a meter usually around 15 ohms.
If infinite ohms (open) the element is toast.
[COLOR="Blue"]
HOW DO YOU CHANGE THIS ELEMENT IN THIS GE DISHWASHER? [/COLOR]
Once you get the kick plate off it is self explanatory.
Check the rubber seal in case you have to also replace them.
