RBG
#1 Posted : Sunday, January 17, 2010 7:41:54 AM(UTC)
RBG
Front load Whirlpool washer will not agitate or spin. Will go through entire cycle and drain without spinning. Checked the belt and is OK.Was making a grinding noise prior to breakdown.
sidfink43
#2 Posted : Tuesday, January 19, 2010 4:33:34 PM(UTC)
sidfink43
This is not a model that is widely in use, and I have only seen one a couple of times, so about the best I can do for you is link you to the manual for some troubleshooting procedures.
https://secured.whirlpoo...9b84/$FILE/WPWASHER1.pdf
