bhurley
#1 Posted : Sunday, January 17, 2010 1:57:19 PM(UTC)
bhurley
I just install a new timer in my dryer and it does not stop at the off position. The cycle stops, the drum and heating element go off but the timer keeps going until it gets to the next off marker.
#2 Posted : Monday, January 18, 2010 12:12:53 AM(UTC)
Replacement parts for WHIRLPOOL LER3624EQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406688.pdf
If this is not the reason you replaced the timer, it sounds like the new timer has a problem.
To check it.
Unplug the machine
Place your meter across the BK/BU timer contacts.
Manually move the dial to the off position that works.
You should see the contacts open.
You now know what the readings should look like when the unit works correctly.
Then do the same thing at the off position that does not work.
If the contacts do not open then you have a timer problem.
