The fill valve won't stop filling and water overflows out the door even after machine is turned off. I have checked the overflow prevention device and believe it to be working correctly. I recently changed the shut off valve under the sink, but I don't see how that could be related. Please help.
THIS FORUM IS DEAD!!!!!!! |
Is this part what is called "water Inlet Valve" ?
