I am having problems and I think it is the timer /swith control. Washer fills, then it should start to wash(agitate) but doesn't all the time. You can here the timer clicking but it won't wash. If I turn knob over to perm press wash it will wash a little then stop, if I turn knob a little it will start again to wash. Then it goes thru spin cycle ok. If this control knob is bad , will that keep it from changing cycles?
