rangerepair
#1 Posted : Saturday, January 16, 2010 10:15:24 AM(UTC)
rangerepair
Approximately 5 weeks ago, noticed that both refrigerator and freezer compartments were not as cold as usual. Upon examination of the freezer section, noticed an ice build up on the rear of the unit(had to be chipped away with a tool). I removed the rear cover of the fridge- fan was operating fine and I vacuumed dust off coils, condensation pan was full of water- I emptied it out and reset it in place. Replugged the fridge and jockeyed with thermostat control. The next morning, fridge returned to proper temperature and freezer operational.
Now, same problem encountered. But this time, the buildup on the rear of the freezer is of a snowy composition, not solid ice. The condensation pan is totally dry. I once again vacuumed the coils and jockeyed the thermostat control(which controls both freezer and fridge compartments).
The freezer compartment is cold enough to keep ice frozen (with a glossy shine), but ice pops are melted. The refrigerator section is not cold enough, even though thermostat setting is at the highest cold level. I usually keep the thermostat at half the current setting and it is very cold.
Would appreciate your diagnosis of the problem and seek your recommendation if this is a job a mechanically inclined individual can tackle on my own!!!
Thank you in advance for your assistance.
Michael
#2 Posted : Saturday, January 16, 2010 11:34:11 AM(UTC)
Liner parts replacement parts for WHIRLPOOL ET8MHKXMQ00 Refrigerator | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202225759.pdf
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 4 in Section 3) till the fans and compressor turn off.
There is usually a hole in the units cover to let you do this without removing the cover.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 4 in Section 4) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove at least one wire to the defrost thermostat (Item 18 in Section 3 ) (clipped onto the evap coils)and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
