timandjulie
#1 Posted : Saturday, January 16, 2010 9:25:13 AM(UTC)
timandjulie
Just bought a house and the dryer came with it. The dryer won't dry clothes in a normal cycle. It gets hot but I have to put in through adt least a cylcle and a half.
#2 Posted : Saturday, January 16, 2010 10:00:59 AM(UTC)
Replacement parts for WHIRLPOOL KEYS750LQ0 | AppliancePartsPros.com
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
