My kenmore advantage dryer (17 years old) will not shut off. It continually keeps going until I manually shut it off. Thanks
I recently repaired a dryer that always ran unless the door was pulled open or the timer turned to an Off point. Found the Start button contacts welded shut (as if you were always holding the button in). Cheap and easy part to replace.
Thank you so much for your quick reply. We will try your solution out in the next day or so and look for the contact parts that you suggested. Regards, Repairs48
