2 Pages12>
mbradyla
#1 Posted : Friday, January 15, 2010 10:52:20 AM(UTC)
mbradyla
This is 2 years old and everything else seems to work just fine, it just doesn't cook. Any ideas as to which part needs to be replaced? :(
#2 Posted : Friday, January 15, 2010 12:49:25 PM(UTC)
Does it make any unusual noise when it runs?
Do the turntable and the light inside work?
mbradyla
#3 Posted : Friday, January 15, 2010 1:06:28 PM(UTC)
mbradyla
Thanks for the questions, everything else seems to be working fine; turntable and lights all work
#4 Posted : Friday, January 15, 2010 4:52:39 PM(UTC)
Check if the microwave will heat on lower power level (User guide, page 11). Put a cup of water, set the power level 2 or 3 and cooking time 2 minutes. Post the result.
mbradyla
#5 Posted : Sunday, January 17, 2010 10:15:27 AM(UTC)
mbradyla
SOrry, didn't see that you responded... I did what you suggested and the water was still ice cold.
THECLARKS
#6 Posted : Monday, January 18, 2010 6:30:30 PM(UTC)
THECLARKS
I have a Maytag UMC5200AAS and after the microwave was has been used and we try to use again immediately it will not heat; just lights up, but will work several hours later. What do you think it is?[/font]
#7 Posted : Wednesday, January 20, 2010 12:31:33 AM(UTC)
Sorry for the delay.
Unplug the microwave and get access to the high voltage transformer as described in the Service manual (page 35) but do not remove it. Discharge the high voltage capacitor, remove the wires from the high voltage transformer primary windings, plug the microwave and check for 120 VAC between these wires while the control calls for heat. Be careful not to electrocute yourself.
If there is no proper voltage, replace the control board.
If there is proper voltage, check the high voltage transformer, the high voltage capacitor and diode as described in the Tech sheet.
If there is nothing wrong, then the magnetron is the culprit.
Here are the breakdown diagrams and Replacement parts for MAYTAG MMV4205BAW Mwave - Mounted Over Range/wo | AppliancePartsPros.com
#8 Posted : Wednesday, January 20, 2010 12:35:57 AM(UTC)
Open the control panel, discharge the high voltage capacitor and check the cooling fan (#16 on the diagram). Post the results.
PM95361
#9 Posted : Sunday, January 24, 2010 4:36:57 PM(UTC)
PM95361
All of the sudden it won't heat. It is also making a funny noise. Lights, etc.. All work. Any ideas?
THECLARKS
#10 Posted : Sunday, January 24, 2010 7:48:21 PM(UTC)
THECLARKS
It's weird; after trying to figure it out; I kept clearing the time and re-tried it again and I was getting ready to push the button to open the door and the microwave started again and that's seems to be the problem; it's some kind of short in the button to open the door?????
2 Pages12>
