dhurwitz
#1 Posted : Thursday, March 13, 2008 12:12:50 AM(UTC)
dhurwitz
:mad: How do I remove the old door handle without dismantling the door? There are no screws under the "Admiral" plate.
#2 Posted : Thursday, March 13, 2008 3:44:09 AM(UTC)
Just remove all the inner panel screws on the handle side, pry open the panel, and tighten the 5/16 handle screws with a socket wrench.
dhurwitz
#3 Posted : Thursday, March 13, 2008 8:52:21 AM(UTC)
dhurwitz
:mad:I removed all of the screws on the handle side but there was no 5/16 screw to remove the handle unless it is under the insulation.
Any additional help is appreciated.
Admiral Freezer model FNF17E8.
Thank you, David Hurwitz
dcrum
#4 Posted : Friday, May 14, 2010 5:10:17 AM(UTC)
dcrum
How do I tighten the door handle. It has come loose.
Guest (4)
