Hello, this dishwasher does not fill. I can hear what sounds like the pump running when I push the on button and one of the function buttons but no water goes in. Do I need a new control module or some other part? I see they are back ordered. How long will it take to get this part thanks Eric
Eric, Remove the kick plate and check for continuity the water inlet valve solenoid (#19 on the diagram). Close the water to the dishwasher and remove the water line tube from the water inlet valve. Check for a sediments build up inside the water valve. If there is ∞ Ohms reading or sediments build up, replace the water inlet valve. - The water inlet valve Part number: AP3783031
