2 Pages12>
locktech
#1 Posted : Wednesday, January 13, 2010 4:43:29 PM(UTC)
locktech
This is a gas range. When I push it to broil and hit start it clicks but won't ignite. When I try to get error codes I hit bake and clock 5 sec and nothing happens. Oven works fine. A day later I tried it and it worked. Today I tried it and it's back to not working. Anyone have any clue to why this is happening?
telephoneman
#2 Posted : Thursday, January 14, 2010 10:00:45 AM(UTC)
telephoneman
I replaced my bake ignitor and still have the same problem, I am now going to test the gas valve/ regulator and see if I get the correct resistance. It could be that one of the solenoids are bad and I need to replace the gas valve/regulator. Hope this helps
#3 Posted : Thursday, January 14, 2010 12:42:31 PM(UTC)
locktech and telephoneman,
You can find some useful information in one of our previous threads: http://forum.appliancepartspros...l-oven-wont-heat-up.html
If you need more specific instructions, post the complete model numbers of your ranges.
telephoneman
#4 Posted : Thursday, January 14, 2010 1:46:24 PM(UTC)
telephoneman
The model is SF380LEPQ2, I'm going to try your suggestion about the gas valve. My problem is when the oven is set broil or bake it is not working. When it is set to broil, I can hear the igniter click and smell a small amount of gas, but on bake, the oven does nothing.
locktech
#5 Posted : Thursday, January 14, 2010 2:07:09 PM(UTC)
locktech
Ok I ohmed them bake or bottom term measured 202. The top or broil is open. Can just one go bad because what I have read say's if one is bad niether will work. The oven works fine just the broiler is out?
#6 Posted : Thursday, January 14, 2010 2:08:07 PM(UTC)
Originally Posted by: telephoneman Go to Quoted Post
The model is SLEPT, I'm going to try your suggestion about the gas valve. My problem is when the oven is set broil or bake it is not working. When it is set to broil, I can hear the igniter click and smell a small amount of gas, but on bake, the oven does nothing.
Check the gas valve/regulator and post the result.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL SF380LEPQ2 30" Gas Freestanding Self Clean Range Sealed Burner | AppliancePartsPros.com
#7 Posted : Thursday, January 14, 2010 2:10:16 PM(UTC)
If you are sure the readings you posted are accurate, the gas valve/regulator has to be replaced.
locktech
#8 Posted : Thursday, January 14, 2010 2:43:21 PM(UTC)
locktech
Model # sf368lepq ohmed regulator terms. top is open bottom is 207 ohms. broiler inop. oven works fine, replace regulator?
locktech
#9 Posted : Thursday, January 14, 2010 2:45:33 PM(UTC)
locktech
yes I checked them several times. I am a ex dealer tech turned locksmith. I used my fluke meter and am very experienced using it.
locktech
#10 Posted : Thursday, January 14, 2010 2:47:51 PM(UTC)
locktech
thanks gene if you ever have any auto or lock questions feel free to ask. I owe you one!!!!
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Whirlpool Accubake Double Oven Lower Oven Door Locked (Oven Repair (including Ranges and Cooktops))
by Malexi 6/2/2017 9:46:25 AM(UTC)
Replacing Thermal Fuse on Whirlpool Accubake (Oven Repair (including Ranges and Cooktops))
by jermainejones 11/20/2016 8:28:24 PM(UTC)
Whirlpool accubake double oven - one oven failed (Oven Repair (including Ranges and Cooktops))
by Pshotts 11/14/2015 5:22:49 PM(UTC)
Whirlpool Accubake Gold (Oven Repair (including Ranges and Cooktops))
by HadleyBE 2/8/2015 7:14:52 PM(UTC)
WHIRLPOOL AccuBake 30" Slide-In Range Touchpad Issue (Oven Repair (including Ranges and Cooktops))
by mservice 2/7/2015 9:23:30 AM(UTC)
outer door installation on whirlpool accubake oven (Oven Repair (including Ranges and Cooktops))
by rldaustin 6/16/2014 4:15:59 AM(UTC)
Whirlpool Accubake Oven Clock display issue (Oven Repair (including Ranges and Cooktops))
by jimkenzie 2/24/2014 7:48:06 PM(UTC)
Whirlpool Accubake Gold Broiler won't shutoff (Oven Repair (including Ranges and Cooktops))
by rtoddwhite55 11/20/2013 2:24:04 PM(UTC)
WhirlPool AccuBake (Oven Repair (including Ranges and Cooktops))
by bakdrft 10/25/2013 11:07:12 AM(UTC)
Whirlpool Accubake Double Electric Wall Oven (Oven Repair (including Ranges and Cooktops))
by chrisgoldsmith 4/26/2013 6:11:04 PM(UTC)
Whirlpool Accubake Electric Range (Oven Repair (including Ranges and Cooktops))
by Ghosthunter123 2/25/2013 6:02:20 AM(UTC)
Whirlpool Accubake Microwave/Oven Combo not working (Microwave Repair)
by Retired AmmoChief001 1/31/2013 5:59:10 AM(UTC)
Whirlpool accubake oven isnt working (Oven Repair (including Ranges and Cooktops))
by chrisdod84 1/18/2013 12:16:23 PM(UTC)
Whirlpool Accubake Double oven (Oven Repair (including Ranges and Cooktops))
by Bachent 1/17/2013 8:34:31 AM(UTC)
2 Pages12>
