kygal42004
#1 Posted : Thursday, January 14, 2010 1:57:22 PM(UTC)
kygal42004
i have an electric dryer that has an interior light.
light stays on when door is completely closed, machine apparently thinks that door is still open as it will not operate
i dried one load and tried to do another but nothing
any suggestions?
:eek:
#2 Posted : Friday, January 15, 2010 2:26:48 AM(UTC)
Replacement parts for WHIRLPOOL LER4634BQ1 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203401728.pdf
Sounds like the door switch (Item 10 in Section 2) is toast.
May also be the switch activation lever (Item 12 in Section 2)
