Paul McGrath
#1 Posted : Thursday, January 14, 2010 10:48:48 AM(UTC)
Paul McGrath
I am ready to toss this machine. I had to replace the Tub Position Sensor after receiving the UC code. I then attempted to use the machine, it sit on Wash Cycle. I then used the Service Mode commands. Every function works, on its own in Service Mode, but not on it's own. I can force each step using SM. I have tried all combination's to find a default mode to reset the machine. Is there, to the best of your knowledge, a reset or default setting I am missing??
I typed the wrong model , it is FAV6800AWW
#2 Posted : Thursday, January 14, 2010 1:09:28 PM(UTC)
Hi Paul,
The Service manual might help to diagnose the problem.
Here are the breakdown diagrams and Replacement parts for MAYTAG FAV6800AWW Washer - Top Loading | AppliancePartsPros.com
