irasend
#1 Posted : Wednesday, January 13, 2010 10:49:21 AM(UTC)
irasend
Moved into a new house and the oven door on this range will not stay closed. Replaced the hinges, but they don't seem to be the problem. It seems that the previous owners must have bent the pins that the hinges rest on. I have tried bending them back, and that lasts for a little while, but if I open the door fully, they must be bending back, because then the door will not close tightly again. As best as I can see from the schematics these pins are not replaceable, but I am open to suggestions.
Thanks:o
#2 Posted : Wednesday, January 13, 2010 2:42:28 PM(UTC)
You may want to remove one of the side panels to figure out exactly what is wrong.
