sassoton
#1 Posted : Wednesday, March 12, 2008 11:14:18 AM(UTC)
sassoton
I have a Bosch smu4052uc dishwasher. When I turn it on and after it pumps out the residual water, it makes a loud vibration. Is this the "Water Valve". If so can it be cleaned or should I simply replace it ??
#2 Posted : Thursday, March 13, 2008 2:53:35 AM(UTC)
You probably have a bad drain pump, you will need to pull out the dishwasher to fix this.
sassoton
#3 Posted : Thursday, March 13, 2008 4:37:13 AM(UTC)
sassoton
Why do yopu think it is the pump rather than the water valve. The pump seems to have no problem moving the water out. The noise seems to be when the dishwasher is trying to fill. If I open and close the door several times then the fill cycle seems to happen with no noise.
Carson1214
#4 Posted : Friday, March 14, 2008 4:05:58 PM(UTC)
Carson1214
Run the "cancel drain" and it will drain the unit that will tell you if the drain pump is the noise maker or the valve which isn't used then.
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Bosch Dishwasher Model SHE3AR56UC/07 (Dishwasher Repair)
by EDK1747 8/30/2023 7:42:58 AM(UTC)
Bosch Dishwasher SHE3AR56UC/07 (Dishwasher Repair)
by Guest 8/27/2023 11:27:21 AM(UTC)
Bosch Dishwasher skips to "clean" even after part replacement (Dishwasher Repair)
by Guest 6/20/2023 5:17:19 PM(UTC)
Bosch dishwasher SHX65T55UC/07 not dispensing soap unless in "Express" mode (Dishwasher Repair)
by callussun 4/19/2023 9:46:00 PM(UTC)
Bosch dishwasher shem3ay 55n/25 (Dishwasher Repair)
by Guest 3/23/2023 5:18:20 AM(UTC)
Bosch dishwasher only drains on reset and specific cycle (Dishwasher Repair)
by vusedad 10/18/2022 8:54:46 AM(UTC)
Bosch dishwasher model SMV41D10EU/48 Not working (Dishwasher Repair)
by adriandlb 10/7/2022 12:18:47 AM(UTC)
Bosch Dishwasher SHX68T55UC/02 Leak Identified: How to Fix? (Dishwasher Repair)
by jonneytaee 8/31/2022 4:48:51 AM(UTC)
Bosch Dishwasher Model SHPM65Z56N (Dishwasher Repair)
by Guest 7/8/2022 9:00:03 AM(UTC)
