Dryer is just about a year old. Service has ben out 2x to replace thermal fuse. I have replaced it once. All this in the last 10 days. My question is why is the fuse still blowing?
I cleaned out the vent pipe.
The fuse only blows when the dryer is on high heat.
The timer makes a clock noise that it never made before or at least that I didn't notice.
Any help would be appriciated. Thank you.
Which thermal fuse, the one on the heater housing or the one next to the cycling thermostat.
It's the one down at the base of the unit, part # is 3392519, connects to two blue wires, I am guesssing that is the heater housing.
