hello i got a admiral model number dwb1000awx heres what its doing i have water hooked up i have power hooked up when i turn the knob to delay the light turns on once i turn it to start or let it go on normal or heavy the light shuts off and the machine does nothing i checked the motor the water inlet the control panel the float everything has power to it and i checked the ohms on the inlet valve and float if i just let the control knob go it will act like its running it will go through all the cycles it just wont do anything does anyone have any clue what could be wrong with it thank you when it goes though the cycles the light for the heating water turns on also
can anyone help me i really dont just wanna start changeing parts
