dinh
#1 Posted : Tuesday, March 11, 2008 1:51:08 AM(UTC)
dinh
Dear,
My oven could not work after self-cleaning.
The clock is still work but can not do anything for setting.
The touch-pad in the control have maltfuntion. Only the pads which show: the roasting with conversion, cancel, 6, 9 are can show up when press on it and the other key pad are dead and no beep sounds either.
What should I do? Is the control panel need the replacement or Control H1 Board? How to know or check about those elements are fails ?
Thanks,
Dinh
#2 Posted : Tuesday, March 11, 2008 4:33:12 PM(UTC)
Hi Dinh,
Open the control panel, remove the control panel ribbon from the control board and clean it, using an eraser.
Plug it back and check if it'll work.
If not then the control panel has to be replaced.
- The part number for the control panel is AP3490588
dinh
#3 Posted : Monday, March 17, 2008 7:03:27 PM(UTC)
dinh
I have replaced the control panel and it worked.
Thank you
:D
#4 Posted : Monday, March 17, 2008 7:31:57 PM(UTC)
I'm glad you were able to fix it.
ou8mynookiE
#5 Posted : Thursday, April 2, 2009 5:50:29 PM(UTC)
ou8mynookiE
hey Gene,
How do I access the Control panel? Can I do it from the front, or from rear of unit.
thanks..
ken
#6 Posted : Thursday, April 2, 2009 6:48:09 PM(UTC)
Ken,
What is the complete model number of the unit?
Guest (6)
