when dw is in run mode, some water pulses out of the lower spray arm, nothing out of top arm. also, machine doesn't drain totally or at all at start of each cycle, like it is supposed to. motor is running and drain solenoid appears to be working. timer is working, water is filling the dw tub. what's wrong?:confused:
