Hi, my Frigidaire dishwasher model #GLD2150RCS1 control panel is frozen. The Normal wash button as well as the wash light indicator button wont stop flashing. The machine will not run, as I cannot clear this from the control panel. Something like this happened before and I was told a sequence of buttons to press on the control panerl to reset it. Unfortunatly, I didnt write it down! I called Frigidaire and after waiting on hold for 25 minutes I was told just to call a repair technichian as it was no longer under warranty. Thanks :confused:
Hi Gene, thanks for replying as quickly as you did. My husband was able to get it working. He removed and cleaned all of the drain screens and then cleaned the latch on the door. It appears that the door wasnt latching completly and this is what was causing the flashing lights and frozen control panel. The diagram you sent for replacing the control panel may come in handy yet. I dont know if there is another problem or not I guess time will tell. Thanks again :)
