krazy4112000
#1 Posted : Monday, January 11, 2010 1:25:02 PM(UTC)
krazy4112000
my electric dryer heats, spins, and vents but clothes are still wet
John @ Fischers
#2 Posted : Monday, January 11, 2010 3:32:03 PM(UTC)
John @ Fischers
Could be a few things, such as Heating element, Hi Temp Limits(s), or Timer, or a volatge problem.
First make sure you have 240v @ dryer plug. If so, the carry on and read this, it will help.
http://forum.appliancepartspros...er-parts-continuity.html
#3 Posted : Monday, January 11, 2010 6:23:56 PM(UTC)
Try this
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
Dryer doesnt dry well (Dryer Repair)
by susanbarton 8/3/2010 7:51:46 AM(UTC)
