I have a whirlpool stove (GR465LXK) that during the self-cleaning mode lost all power to the control module (stove top works but not the oven electronics – I now find out this is a common problem and the self-cleaning mode should not be used).
According to research I've made so far, the thermal fuse is supposedly the culprit. However, I don't think the problem is the thermal fuse since it has both continuity (ohm meter test) and even when bypassed (jumped) nothing happens. What else could the intense heat of the self-cleaning mode have destroyed? Thank you, AL
Rank: Administration
When you say thermal fuse, are you referring to #26 on the diagram below labeled CHASSIS PARTS? There is another fuse inside the control panel. See # 19 on the diagram labeled CONTROL PANEL PARTS below. Let me know...
Both fuses checked out okay. AL
When you were checking the fuse inside the control panel, did you remove at least one of the wires from it? If not, remove one wire and try again.
By the way, that fuse is connected to a brown wire between the power board and microcomputer.
Yes, I checked the fuse (connected to the brown wire) for continuity with one side disconnected and I also jumped it, but no success.
I did notice that the transformer on the power board "may" have overheated. It has a dried dark yellow substance on parts of the exterior, primarily the top and back. Not sure if this is the way it looked when new?
Thanks again for your help, AL
I'm not sure I checked the correct places, but I have power (115V) at the Blk and W wires at P1 and I have power (115V) at the red and black wires at P8.
Hi alfrenzel The power board looks very suspicious to me. If you have 120V across P1-1 and P1-4 terminals (incoming power) and you did not measured a 120V at the P7 plug (across P7-2 terminal and any other terminals), no doubt the problem is the power board (most likely the low voltage transformer). The part number for the new power board is AP3135669Good luck. Gene.
just curious, i always check to make sure i have proper voltage coming into the unit first .. i find that self-cleaning can cause problems with wires ...however, it is always a good practice to check incoming voltage..
