Was working fine last week then something quietly died. I browsed the forum but din't find what I needed. I did measure the ohms across the broiler igniter, I think. 102 ohms I do not have a parts layout to be sure that was it even. I do have the schematics from the back side of the range. So, I'd like to see the parts layout I could print out, please. Couldn't print the one online. Anyways...the top burners work just fine... I'm guessing that the igniter isn't getting the signal from the EOC? Not gonna guess my way through this one. Your help would be greatly appreciated. Thank you, Roy
Have you tested 120 vac to your ignitor? If correct voltage is present to the ignitor, when controls are set to bake, replace the ignitor. Back to Results Igniter kit for oven burner, flat style. - By Frigidaire. Length - 3.72". Replaces any flat oven igniter (excluding blue ceramic igniters). Part Number: AP2150412 Made by FRIGIDAIRE Our Price: $41.64 Compare at: $65.23 You Save: $23.59 In Stock Order now and it will ship Tuesday Quantity
I checked the voltage going to the igniter and it's only 6.7 VAC. The indicator lights do come on and the preheat light comes on after a few seconds too. Still no flames.
If your not getting 120 VAC to your ignitor when set to preheat or bake and I hate to be the burden of bad news but it sounds like a control board issue ... 6.7 VAC is incorrect voltage. Back to Results Clock Part Number: AP3672819 Made by FRIGIDAIRE Our Price: $158.06 Compare at: $186.51 You Save: $28.45 In Stock Order now and it will ship Tuesday Quantity
