muffy94
#1 Posted : Saturday, January 9, 2010 11:45:39 PM(UTC)
muffy94
Had this issue before a couple years back. Watched repairman replace a part at the bottom of the unit. Seemed to be a farly simple job, but of course I didn't note the part he replaced. Any ideas/suggestions would be appreciated.
sidfink43
#2 Posted : Sunday, January 10, 2010 3:39:12 PM(UTC)
sidfink43
If the motor is running and the pump will drain things it is probably the coupling.
This video will show you how to change it out.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
muffy94
#3 Posted : Monday, January 11, 2010 11:37:06 AM(UTC)
muffy94
Got the coupler this AM and had it in by mid-morning! Although I wasn't as fast as the guy on the video, the end result was the same. Thanks a bunch!
The new coupler is reinforced with metal sleeves, so it should last longer this time.
sidfink43
#4 Posted : Monday, January 11, 2010 11:52:55 AM(UTC)
sidfink43
Well, none of us do it as fast as the folks in the movies.
Glad you got it fixed and thanks for the update.
Guest (5)
