[FONT=Calibri][SIZE=3][COLOR=#000000]Take control panel down; if the timer is gray I am almost sure the tabs that hold the timer in place are broken. In any case check to see if the timer is loose. If the tabs are broken/loose you may be able to put a large washer on the screw to hold it in place. You may have to replace the timer. [/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]If not the timer is bad unless it is something with the knob. [/COLOR][/SIZE][/FONT]
Clothes Washer Repair Guide
