meatloaf
#1 Posted : Saturday, January 9, 2010 7:38:39 AM(UTC)
meatloaf
It is getting power. Dryer light comes on, breaker is fine. When I push button will not start.:confused:
magician59
#2 Posted : Saturday, January 9, 2010 8:07:21 PM(UTC)
magician59
Are you getting 240VAC at the outlet?
#3 Posted : Sunday, January 10, 2010 6:37:36 AM(UTC)
Here are your parts includes a wiring diagram
Base, heater & motor replacement parts for MAYTAG MDE3706AYW Dryer - Ele | AppliancePartsPros.com
Looks like the unit runs the interior lamp off the L2 side and the motor uses the L1 side so ensuring you have the L1 side is a requirement as magician59 said.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If power is good, you know it is a machine problem.
Most likely cause is the thermal fuse Item 6 in Section 1.
Unplug the unit and check it with a meter should be 0 ohms.
If blown replace it but be sure to clean/check your vent system as this is the most common cause of it blowing.
Also the start switch and door switch are likely causes.
And last of all the motor itself or the timer.
Guest (4)
dryer stop working (Dryer Repair)
by howardr57 2/18/2013 10:08:28 AM(UTC)
Dryer stop working (Dryer Repair)
by premiumgroh 9/27/2009 3:51:13 PM(UTC)
