irhoghead
#1 Posted : Saturday, January 9, 2010 4:32:08 PM(UTC)
irhoghead
The timer on this dryer will not advance no matter what setting it is set to. I have checked the continuity on the timer, the multi-temperature thermostat, and the hi-limit thermostat, and they all check out OK. Where do I go next? Thanks for your help.
magician59
#2 Posted : Saturday, January 9, 2010 6:52:56 PM(UTC)
magician59
If the timer doesn't advance, open the console and make sure there are no disconnected wires. [COLOR="Red"]DON'T TOUCH ANY WIRES OR CONNECTORS, UNLESS YOU FIRST UNPLUG THE DRYER.[/COLOR]. If nothing is disconnected, replace the timer. Here's the part number. Part number: AP4043236
