Replace igniter two months ago (old one had cracked) ... all was well until recently ... now oven slow to warm up ... thinks it's warmer than it is (temperature reading will quickly climb, but temperature is clearly nowhere near actual temp) ... no fault codes ... bad temperature sensor? Igniter glows orange (not white) but gas is flowing. Time to get a new oven will everything starting to break?
