The steak grilling feature works, but the steak does not seem to cook all the way. I see that there are two elements in the ceiling of the microwave, but only the outer element will light up. I'm assuming that these elements burn out over time. #1--is this the problem #2--should I replace both elements at the same time #3--how in the world do these elements come out? stanhonda@verizon.net:confused:
i'm not sure how to fix your problem but was just curious if steak in the microwave is any good?
