ADAMSPAKA
#1 Posted : Wednesday, December 2, 2009 11:23:04 AM(UTC)
ADAMSPAKA
I Have The Pck2003 Conversion Kit For My Dryer, But There Are No Illustrations With The Instructions. The Instructions Refer To Figures 1 - 6, But They Are Not Shown. Any Idea Where To Get Them? The Regular Parts Diagrams Are Not Detailed Enough.
ButchJ
#2 Posted : Tuesday, January 5, 2010 8:37:39 AM(UTC)
ButchJ
I have EXACTLY the same dryer and EXACTLY the same problem/scenario
NO illustrations to follow and the instructions are too generic
I did the conversion but am not getting any propane to the burner
HELP HELP!!!!!
onerockman
#3 Posted : Tuesday, January 5, 2010 9:46:10 AM(UTC)
onerockman
From what I can see. you need to change the Orf. and the rear piece. also the burner . Does the inst. say anything about a spring change inside the reg. If not compare the rear piece to the old and see if their is a spring inside a different lenght will change the regulator pressure. Nat. should be apox 6-7 inches of WC (Water Collum) LP runs at 11 Inches WC "NOT LBS"
SublimeMasterJW
#4 Posted : Tuesday, January 5, 2010 10:46:54 AM(UTC)
SublimeMasterJW
