Stove at some point was switched from Fahrenheit to Celsius. Have looked all over for a user/operations manual for the stove but have had no luck. Any idea as to where I can get the user/operator manual or switch the stove back to Fahrenheit?
Regards, -Eugene
Eugene,
The model number you posted does not come up. It might be incorrect, incomplete or just too old.
You can try this: Hold either timer keys down on power up. The right digit will display "F" or "C". The temperature display can be toggled from C to F by pushing the Broil key.
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
[FONT='Tahoma','sans-serif'][FONT='HelveticaNeue-Roman','sans-serif']The temperature is preset at Fahrenheit, but can be changed to[/FONT] [FONT='HelveticaNeue-Roman','sans-serif']Celsius.[/FONT] [FONT='HelveticaNeue-Bold','sans-serif']1. [/FONT][FONT='HelveticaNeue-Roman','sans-serif']Press and hold the upper oven BAKE and CANCEL pads[/FONT] [FONT='HelveticaNeue-Roman','sans-serif']for 3 seconds. A beep will sound and the current setting[/FONT] [FONT='HelveticaNeue-Roman','sans-serif'](°F or °C) will appear in the display.[/FONT] [FONT='HelveticaNeue-Bold','sans-serif']2. [/FONT][FONT='HelveticaNeue-Roman','sans-serif']Press AUTOSET to change the setting. Wait 4 seconds for the[/FONT] [FONT='HelveticaNeue-Roman','sans-serif']new setting to be accepted.[/FONT] [FONT='HelveticaNeue-Roman','sans-serif']If AUTOSET is not pressed within 30 seconds, the control will[/FONT] [FONT='HelveticaNeue-Roman','sans-serif']return to the existing setting.[/FONT][FONT='Arial','sans-serif'][/FONT] [/FONT]
