Hello,
I have a "GE Manual Clean Electric Range". 30 Inches wide, Model #GRMF3201ZWW.
Everytime I do a search to try and find parts (on various sites) I get told that my model doesn't exist. I'm not sure if this might be because the range was made for the Canadian market??
I am getting the F3 Error, I have checked the probe, wiring harness, and circuit board. It's time for a new circuit board!
I'm hoping someone will be able to provide me with the correct part number or give me a replacement model number for the model that I own so that I can search for parts.
Thanks for your help!!!!
If in Canada have you tried calling your local Mabe parts distributor, they handle GE?
Like you I could not find any info. You could remove the board and see if it has a part number on it and then use that to cross reference. |
THIS FORUM IS DEAD!!!!!!! |
I have the same problem as AHMICAIR. I have the same range and each time I try to look for parts I am told there is no such model.
I am getting an F1 code and need to replace my temperature probe and my electronic circuit board. Help!
