russisawesome
#1 Posted : Saturday, January 2, 2010 8:35:30 AM(UTC)
russisawesome
top rack does not recieve water. bottom rack washes fine but top gets nothing. this model does not have a power tower but pumps the water to the top thru a tube on the outside right side. the water only goes halfway up and then stops. is there a pump only for this purpose or does the main pump and motor do it all?
magician59
#2 Posted : Saturday, January 2, 2010 8:41:28 AM(UTC)
magician59
Looks like a restriction or obstruction in the delivery tube to the top spray arm. Could also be dirty jets in the upper spray arm.
russisawesome
#3 Posted : Saturday, January 2, 2010 9:27:57 AM(UTC)
russisawesome
i looked when it was running and the water goes halfway up the tube. so maybe if the jets are dirty it is impeeding the water?
and i guess there is not a separate pump for this spray arm?
magician59
#4 Posted : Sunday, January 3, 2010 3:54:02 PM(UTC)
magician59
If you'll click on your posted model number, you'll see the parts breakdown for your machine. I don' know of a model that has more than one circulation pump. Try running a cycle without dishes, using Dishwasher Magic. That should help clean the spray arm jets.
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
Mystery Ball Check Valve Shows Up In GE Dishwasher Pump (Dishwasher Repair)
by lokar 9/29/2021 8:04:19 AM(UTC)
Frigidaire Dishwasher Pump Wont Stop (Dishwasher Repair)
by badblue06 8/3/2014 6:54:58 AM(UTC)
Frigidaire dishwasher pumps water but doesn't wash (Dishwasher Repair)
by woodstock 3/19/2013 7:00:51 AM(UTC)
GE dishwasher pumps water out right away (Dishwasher Repair)
by redbeard 3/26/2012 8:23:13 AM(UTC)
Lubrication for KitchenAid Dishwasher Pumps and Seals (Dishwasher Repair)
by jsz 12/26/2011 4:36:43 PM(UTC)
Dishwasher pump not working (Dishwasher Repair)
by traain 12/20/2011 3:17:04 PM(UTC)
Dishwasher pumping out water during wash cycle (Dishwasher Repair)
by mcscott 7/2/2011 12:19:13 PM(UTC)
Dishwasher Pump seal replacement (Dishwasher Repair)
by mkapad 4/15/2011 7:20:50 AM(UTC)
dishwasher pump (Dishwasher Repair)
by sergioge 2/20/2011 5:27:51 PM(UTC)
Whirlpool dishwasher pump/motor (Dishwasher Repair)
by RandallRock 1/1/2011 11:19:56 AM(UTC)
kenmore ultrawash dishwasher pump filter (Dishwasher Repair)
by wheels16 12/22/2010 2:14:10 PM(UTC)
Admiral dishwasher pump assembly (Dishwasher Repair)
by OhYeahGreg 11/18/2010 1:22:50 PM(UTC)
ge undersink dishwasher pump/motor hookup (Dishwasher Repair)
by gwolever 11/13/2010 7:51:24 AM(UTC)
