All Wet
#1 Posted : Sunday, January 3, 2010 1:45:02 PM(UTC)
All Wet
This machine was a gift from the UPS guy. Worked well for about a year. The cover of the start button was (is) missing. It still worked fine. A couple of months ago it went south. Wife turned it on, the lights all blinked and then nothing. Took the door off and could see a trace of where water trickled across the control board. The start button no longer works at all. It does not depress. Does it sound like a good place to start? (the control board) Also, would you know if the covers are available for the control buttons? Thanks, Bill Hope it's not too late to wish everyone a Happy New Year!!
All Wet
#2 Posted : Monday, January 18, 2010 12:49:18 PM(UTC)
All Wet
If my e mail addy is needed, it's impala2drht@yahoo.com. Still having probs. Thanks.:mad:
#3 Posted : Monday, January 18, 2010 1:29:58 PM(UTC)
Cannot find any info on this unit, please check the model number.
All Wet
#4 Posted : Monday, January 18, 2010 2:10:09 PM(UTC)
All Wet
Kitchen aid model KUDI01FKWHO Serial FM1001367:)
#5 Posted : Monday, January 18, 2010 11:50:36 PM(UTC)
Here are the parts
Control panel parts replacement parts for WHIRLPOOL KUDI01FKWH0 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208531259.pdf
[COLOR="Blue"]The start button no longer works at all. It does not depress. Does it sound like a good place to start? (the control board).[/COLOR]
I would check the fuse Item 6 in Section 2 first. Should be 0 ohms.
Also you have to replace the start switch Item 2 in Section 2.
And you need a new console Item 1 in Section 2.
Then you could look at the control board, odds are that it also is shot.
[COLOR="Blue"]Also, would you know if the covers are available for the control buttons?[/COLOR]
Looks like it is in stock
The user interface (switch board) is out of stock so you would have to check on it's availability.
I am not sure that it makes sense to put that many dollars into this unit !!
All Wet
#6 Posted : Thursday, January 21, 2010 3:26:00 PM(UTC)
All Wet
According to the amount of posts you have made, I am confident you are the man and this is the right site to be. I am on disability, this is a project I am willing to take on. The money spent does not compare the the cost of a new unit. All I can say/do is that I tried to save a buck, and if successful, you get all the accolades. The help is certainly appreciated. I have the control interface in the mail on it's way. Will check fuses. Thank You, will be in touch with progress. New ones start @ around $600.00 w/stainless interior.
All Wet
#7 Posted : Monday, January 25, 2010 10:49:28 AM(UTC)
All Wet
Have the new switch panel. Looks like the right one too! Happy about that. I can't locate the fuse you mention. Looked all over with no luck. Any help there?
billyquiet
#8 Posted : Tuesday, January 26, 2010 5:52:14 PM(UTC)
billyquiet
The fuse is number 6 in the wiring diagram. Should be right there by the conrol board. You need to replace the wires too there is direction on this site as how to do that. You can jump it for a second to see if that is the problem BEFORE replacing any of your parts with your new ones. But if you have a tester there would be o ohms with the wires disconnected and just testing the fuse
All Wet
#9 Posted : Thursday, January 28, 2010 11:58:36 AM(UTC)
All Wet
BillyQ, I had the user interface control board ordered already. I have replaced that and dishwasher is operating properly. Two of the buttons have no covers on them, so as to prevent any water dripping down onto the new board, a small square of black tape is a good, quick fix. Thanks to all for the help!
All Wet
#10 Posted : Saturday, February 20, 2010 1:55:08 PM(UTC)
All Wet
Alas, it has conked again. Wife popprd a circuit breaker in the kitchen and just discovered it has no power to it. So, I'm back looking for the fuse to check. It's suspect. If I can find it this time. Thanks guys.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
