AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer stoppped in middle of cyc, will not restart. HELP
have power to unit, sticker on inside of unit say something about replacing thermal cutoff and Hi limit thermostat? will this help? :confused:
Hi Dustin,
In order to provide most accurate advise I need the complete model number of the dryer and more specific description of the problem.
I'll get that info to you asap. Thanks for your help, I just moved to Northern Arizona, two hours away from a big city. I can fix just about and thing, just need some advise. Thanks again, keep an eye out for me. I should have that info tonight posted. Dustin
Gene, thanks again, here's some info. Roper Dryer, Model# rex4625ew2 type: 122-00 I was drying some clothes, walked out to the shop to se if they were done and noticed that the clothes were still a little damp and the timer still show about mid cycle. I tried to re start and nothing, i tried the other two cycles and nothing. I tested outlet and I have power. Do you need any other info? I can fax you the wire diagram, I found it in side the top cover. Let me know what you think. Thank you so much!!!!!!:o
Dryer Repair
