Karolina Bys
#1 Posted : Tuesday, March 4, 2008 6:06:51 PM(UTC)
Karolina Bys
My washer after first agitating will stop.It would not drain the water and go to the next cycle(rins and spin).I checked pump(is good),put in a new timer, but the problem appears the same.
bambiblaster
#2 Posted : Tuesday, March 4, 2008 6:25:59 PM(UTC)
bambiblaster
You need to check the lid switch.. lid down should have continuity / up none.... But i would say this is your problem
