My Amana Refrigerator which is about 8 years old and is now acting up. The ice maker is malfunctioning (stopped working) and the freezer is not cooling properly. The frig side and the water on the door, work fine. I have vaccummed the front and back areas (including the fan). What else should I do ?
Any suggestions are appreciated....
Thanks, Rick
my ice maker is not freezing i think it is cycling to soon which is not giving it time to freeze properly. it is a brand new ice maker that i ordered. are there any adjustments on the icemaker that i can adjust
Originally Posted by: James Richards  my ice maker is not freezing i think it is cycling to soon which is not giving it time to freeze properly. it is a brand new ice maker that i ordered. are there any adjustments on the icemaker that i can adjust What is the exact temperature in the freezer? How long time takes for one cycle? Gene.
An odd event occurred today, the ICE maker cycled and made a set of ice cubes. I dismantled the rear freezer panel and found the top two layers of the coil had ice on them. Not sure what to do next ?
im not sure what the temperature is but it is set at the coldest maximum temp and is working properly for the frozen foods that are in the freeezer
my ice tray that catches ice is full of frozen water and frozen ice is dripping out of the trays
Turn the ice maker off to stop the water leak and measure the temperature in the freezer.
What is the complete model number of the refrigerator?
TS125TW Amana refrigerator
James,
Have you turned the ice maker off and measured the temperature in the freezer?
